01 CLK 430 high beams not working
2001 Clk 430 Vert 1984 Buick Grand National
My high beams arent working on my car, I checked the fuses and theyre fine. Does anyone know what the problem might be? Thanks.
It is most likely your turn signal switch, the actual part that you turn on the high beams and your turn signals and wipers, mine went bad and my high beams would not work but everything else on the switch did. Easy DIY the part is about 120 at the dealer and you have to remove the steering wheel to get to it.
