rear bolt stuck
Old Mar 28, 2011 | 07:15 PM
jbenz2001's Avatar
2001 clk 320
rear bolt stuck
so today i attempted to change my spring pads in the rear but couldnt get the control bolt off. it seems that the bolt is stuck with the bushing sleeve.is there any way that it can be loosened by using wd-4o or am i better off just cutting the bolt? if so where can i get the bolt other then the dealer? thanks
Old Mar 28, 2011 | 07:28 PM
pnsji's Avatar
2 55s
Do you have picture of the situation?
Perhaps you should use a jack to support the lower control arm. Jack it up a little to make the sleeve level with the bolt.
Old Mar 28, 2011 | 07:35 PM
BABYBENZZZ's Avatar
BENZ w203
yoooo
jack her up a bit, and push it out lol
Old Mar 28, 2011 | 07:52 PM
jbenz2001's Avatar
2001 clk 320
i tried that already.i kept jacking the car up and down and had a jack stand under the control arm and nothing.the bolt is really suck to the sleeve inside the bushing.i can c the sleeve move back and fourth.
Old Mar 28, 2011 | 09:45 PM
pnsji's Avatar
2 55s
Put the car on jack stand. Use jack underneath the control arm. The spring is pushing down the arm, therefore use the jack.
LOL at babybenz
Old Mar 28, 2011 | 10:53 PM
jbenz2001's Avatar
2001 clk 320
I've already done that is what I'm try n to say.I've done this twice already.I know its not tension its the bolt and sleeve to the bushing that's stuck together.
Old Mar 29, 2011 | 12:15 AM
pnsji's Avatar
2 55s
Are you referring to bolts number 32(facing the disc brake) or 38?
Old Mar 29, 2011 | 12:21 AM
BABYBENZZZ's Avatar
BENZ w203
He needs some heat and to take a leak on it
poor guy needs a tech to help, bring it to my garage
Old Mar 29, 2011 | 11:48 AM
jbenz2001's Avatar
2001 clk 320
im referring to 38.i might just try putting heat on it. babybenzzz no i dont need a tech i just dont have alot of time to be working on my car trying to figure out how to take the bolt out if somebody knows the answer.
Old Mar 29, 2011 | 02:10 PM
pnsji's Avatar
2 55s
You might try to use your ratchet/wrench to unwind the bolt.
Old Mar 29, 2011 | 05:38 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
you do know that what you are talking about is a sleeve. Unless it got bent somehow the bolt should slide out if lined up correctly. If it doesnt pull out I would suggest using a bar from the other sidde and hamering it out. Carefull though if the hole is not lined up the bar will get wedged also.
Old Mar 29, 2011 | 08:24 PM
jbenz2001's Avatar
2001 clk 320
yes i do know its a sleeve. i mentioned it in my post.using a ratchet or wrench is the only way to take a bolt.so of course i did that already.like i said before the bolt is stuck to the sleeve.im gonna try heating up the bolt and sleeve and hopefully it comes out.if not im cutting the bolt off.
Old Mar 29, 2011 | 08:38 PM
dlbehrns's Avatar
99CLK320,
If bolt 38 it to the outside, nearest the wheel, then you should remove 34. the control arm pivots from that point. there is no bushing to deal with there. that will allow the control arm to move down away from the body and release tension on the spring. There are some pics somewhere on this forum that show it. which ever bolt is on the inside is the one that needs to be removed I believe.
Old Mar 29, 2011 | 10:54 PM
BABYBENZZZ's Avatar
BENZ w203
Why dont you loosen the axle nut, put the jack under #32 and loosen that bolt a lot easier then, #38
Old Mar 30, 2011 | 12:12 AM
jbenz2001's Avatar
2001 clk 320
Babybenzzz 38 is the easiest.its the one located next to the diff.one bolt and its out.the other one has the sturt and another stabilizer bar connected to it.
Old Mar 30, 2011 | 12:16 AM
BABYBENZZZ's Avatar
BENZ w203
LOL
your talking to a BENZ TECH, that has more experience behind your wet ears!
Old Mar 30, 2011 | 12:27 AM
jbenz2001's Avatar
2001 clk 320
Whoops I meant strut not sturt lol.where can I get that same bolt or can I just replace with another hardend bolt the same size?
Old Mar 30, 2011 | 02:51 AM
jbenz2001's Avatar
2001 clk 320
It doesn't matter thatyour a tech have you've done this type of work on a w208.when does taken one bolt off harder compared to mutiple.if I take the axle bolt off and put a jack under #32 I still might have to take off the bolt to the strut and small control arm connected to it.ill stick to dealing with #38.everybody does it like that.
Old Mar 30, 2011 | 10:47 PM
dlbehrns's Avatar
99CLK320,
I meant to say bolt #32 is easier but have it your way.
Old Mar 30, 2011 | 11:17 PM
Silv430ClkR's Avatar
2002 Clk430
Make sure you have the nut off, put the jack right up to the lower control arm under the spring, jack it up a bit to support the spring tension and hit it out with a hammer from the end that had the nut. The bolt does not thread into the sleave but make sure it is lined up correctly or YOU WILL STRIP THE THREADS!
Old Mar 30, 2011 | 11:23 PM
BABYBENZZZ's Avatar
BENZ w203
any luck mr. 3 day mission lol
Old Mar 31, 2011 | 01:02 AM
jbenz2001's Avatar
2001 clk 320
I haven't worked on the car since the day baby.thanks for asking baby lol.u wanna know anything else baby?
