How long?
Old May 24, 2003 | 02:04 AM
whiteyford's Avatar
How long?
I'm sure I've read this somewhere before, but generally how long does it take for the springs to fully adjust to the height they will eventually settle at. I would assume that all lowering springs are different but I'm just curious if anyone has an approximation.
And also I used the existing pads when i changed the springs. I 'm located in Canada and the dealer told me that there are 5 different types of pads and in Canada they're are measured in millimeters and the stock ones were 9mm. The smallest that apparently are available from the dealer. Are these the best ones to use.
Old May 24, 2003 | 04:50 AM
Supra's Avatar
CLK320 & SLK230
should be around 1,000mile ( pls correct me if i m wrong )
BTW , where r u located in Canada ???
Old May 24, 2003 | 11:43 AM
whiteyford's Avatar
Out west in Edmonton, Alberta. Let me tell you from where I'm from there is know one modding Clk's that's for sure. Which is good for me I guess. I stand out more but finding anyone to do work for me that actually knows what they're doing is pretty tough. Where are you? Never mind i just realized you're from Hamilton.
Old May 25, 2003 | 06:46 PM
superfly_430's Avatar
after about 4-500 miles of driving, your springs will 'settle' and stay at the height it will be at...
