What should resistance be on OEM plug wires ?
2000 CLK430 Cabriolet
I want to test my wires for resistance.
What resistance would indicate that my wires are good on my year 2000 CLK430 ?
So, the thing to do is to not respond to any postings. Hmmm, so that's the way forums work. Imagine that. Foolish me. I thought we were supposed to respond. Oh well.
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
They should be 2000ohms, although from experience I've found leads within this resistance to be faulty and leads outside this resistance to be servicable. A oscilliscope is still the best way to check them.
Am going to use my meter to test each one just to know which one is bad, then will replace the whole set.
One last question: Have you any info on how to test a coil ?
Again, your info is much appreciated. Thanks.
PS. An oscilloscope. Imagine, having your own oscilloscope. Would be nice, and I like the mad scientist angle, too. Maybe someday. I don't think they have them at Harbor Freight.
Unfortunately the coils have a diode in the secondary coil so they can't be tested with a ohm meter. They very very rarely fail, if they do then they usually dont fire at all. I've only ever seen one that was intermitant and that was in training (and even that I think they tampered with it to actually make in fault intermitantly).
Id stick with the bosch leads, but thats just a personal preference.
