Disecting the AC Control unit
Old Dec 10, 2011 | 05:05 AM
fullmetaljacket's Avatar
CLK 230 KOMPRESSOR
for 3 hours I tried dismantling and disecting the AC Control unit to replace its blown bulbs but cannot seem to pass a 3mm clearance when clips have been unclipped :-( I have un hooked all the teeth but it just wouldn't open up fully. I'm afraid id break something because it cost around $200 bucks :-( any help and info would be much appreciated :-)
Old Dec 10, 2011 | 10:00 PM
VIPclk320's Avatar
CLK W208
yours is the european model climate control its different than teh one we got here in the states, I actually like yours much better than ours, haha. try searching ebay us under slk r170, its the same one as yours and should be much cheaper. gl
Old Dec 11, 2011 | 07:23 AM
CLK 230 KOMPRESSOR
hey vip, thanks again. I was able to pop the rotary switches out and was able to change the blown bulbs on the dials. but I still cannot access the button light bulbs for the circ, EC and rear defog. I'll try ebay again as you've suggested.
Oh by the way, a crucial tip on replacing the peanut bulbs on the AC Control unit - take note that the AC Control unit button and dial light bulbs only light up when the ignition key is in ON position or if the engine is running. Turning on the park lights alone will not activate the AC Control unit dial and button lights.
Old Dec 11, 2011 | 01:50 PM
VIPclk320's Avatar
CLK W208
yes thats correct, because the AC/heater is not powered until ignition is on second position or the engine is running.
Old Jul 21, 2012 | 05:07 AM
SuperChargerE55's Avatar
E55 AMG V8 Kompressor 2004 E 55 AMG Type: 5,439 cc (5.439 L; 331.9 cu in) Supercharged V8 Powe
How did you get the AC Control unit out? I need do the same thing mate some tips would be great?
I don't see any holes for the keys like for the radio so I cant figure it out else I properly brake something lol
Thanks for the reply, found it myself to me 15 min taking it out replacing the bulbs putting it back,, ;-) just a hint.
