traction control
Old Dec 16, 2011 | 12:08 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
traction control
Hi Al
I have had a weird problem the last 2 days. When I am on the freeway my TC comes on out of no where and starts applying the breaks. I have had it come on randomly before but for just a second. Now on the freeway I have to turn it off to get it to go stop.
Any ideas? I am hopping it is a bad wheel sensor
also I am pulling a code for a gross evap leak with no CEL. I can smell fumes when the heater is on but haven’t be able to find the source. My purge valve still works and the lines going to it are good so....
Again any ideas,
Old Dec 16, 2011 | 04:06 PM
insame1's Avatar
could it be that my front right tire was flat?
Old Dec 16, 2011 | 11:03 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Yep, most likely just the car reacting to the flat tyre.
Old Dec 16, 2011 | 11:35 PM
AMG_BENZ's Avatar
None
So, there is a wheel sensor for a flat tire...I've never thought about it.
Old Dec 19, 2011 | 10:54 AM
insame1's Avatar
strange thig was it is the front passanger side. PO had run flats so it is hard to tell when it is flat. ther was only 10psi. got that fixed and havent had the issue again. now i just got fix that damn evap leak and I am good to go.
