Need Stereo Help - 99clk w/Bose
Radio says "Muted". After lots of searching, people are stating to remove the "mute wire" going to the back of the radio. Great, should be an easy fix. Pulled out the radio and took a look at Pin 3 on the bottom most wire harness. Oh, there's no wire or pin there. WTF? Now what? I look to the top connector and it only has 3 wires coming in, and the wiring diagram I'm looking at says it should be for power. The Middle connector should be for the speaker outputs, if I'm correct? Help?
Also, now it's asking for a radio code. I have SN if anyone can pull the code for me...
Radio model = 2299
SN = AL 229 W0509460
