Cab antenna....I can't remember...
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Is the mast replaceable? This is that stiff rubber mast that is only on the cvt. Can somebody gimme some insight or a part number? Thanks if you can....
Part numbers for Antenna assembly
Mast (to left of trunk)
208 820 0075
Base (only if you need it)
208 820 01 75
Amplifier (only if it shows signs of corrosion)
208 820 07 89
Thanks--does it...
Pull straight out of the top,or is it threaded, or...thanks again.
