Just lowered
Old Jun 19, 2003 | 03:40 AM
hinhin7's Avatar
MB
Just lowered
Hey guys, finally, my car is lowered now. I am using spring pad #1 all around and H&R springs + Koni sport shocks. The eibach sway bars will probably be installed next week.
Personally, I like the drop, it looks cooler compared to the stock height.
Still waiting for the tires (will be put on Brabus wheels, Mono V)
Solihin
Old Jun 19, 2003 | 03:42 AM
hinhin7's Avatar
MB
another one (picture is not clear though..sorry)
Old Jun 19, 2003 | 04:12 AM
Mach430's Avatar
Looks great! How do you like it? What did you set the Koni's to?
Old Jun 19, 2003 | 10:42 AM
JamE55's Avatar
Out Of Control!
Thumbs up
Looks better!
Old Jun 19, 2003 | 11:13 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
looks good... what was your overall drop front/rear? How is the ride...??
Old Jun 19, 2003 | 05:57 PM
hinhin7's Avatar
MB
Thanks guys
Ben: the guy who installed the springs and shocks, set it to the firmest (no.3) cause he said that is what the instruction says.
Danny: i didn't measure the height before and after. the drop is probably around 2 to 2.5 fingers. So, I would say maybe 1.75"...
The ride is not so bad especially on highways, I hardly noticed it. But when it comes to bumpy road, then you will get a slight harsh ride.
I just got hit in the parking lot a couple days ago. The damage is not so bad. Just dent on the trunk and scratches on the rear bumper. The guy hit my car when I was shopping in the grocery store and ran away. :-(
So, while im still waiting for my tires, im going to fix the car. Ill post some pics when my car is done :-)
Solihin
Old Jun 19, 2003 | 06:39 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Thumbs up Sweet!
The car looks sweet......Congrats and Happy Cruisin'!
Old Jun 19, 2003 | 06:59 PM
nellee's Avatar
2002 CLK320
where did you get eibach sway bars from? I thought they were discontinued or are you referring to the AMG sway bars?
Old Jun 19, 2003 | 07:09 PM
CLK_Ivan's Avatar
2001 CLK430
Looks great!
Old Jun 19, 2003 | 09:07 PM
hinhin7's Avatar
MB
I believe it is an eibach sway bars (same bars as the CLK55)
Check with Ben for sure.
Solihin
Old Jun 19, 2003 | 09:26 PM
Mach430's Avatar
Yes, the bars are the same.
It is not necessary to have the shocks set to #3. If you are happy with it, leave it there. Othewise, you may want to try #2 all the way around.
Old Jun 20, 2003 | 04:53 PM
hinhin7's Avatar
MB
Ben, how does the shock setting affect the performance?
Would the stiffer setting tends to have less body roll than the softer one?
Would the Eibach bars greatly reduce the body roll compared to the stock bars? Im hoping to have the bar installed by next week.
Thanks,
Solihin
Old Jun 20, 2003 | 06:56 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Wow, the drop looks good!
Does this mean now you'll have time to ship the COMAND back?
-s-
Old Jun 20, 2003 | 07:34 PM
Asmod3us's Avatar
1988 300ce
hinhin7, what size wheels are those? Thanks
Old Jun 21, 2003 | 03:48 AM
hinhin7's Avatar
MB
Scorchie: Im sorry for being slack.. I will have them shipped tomorrow. Sorry for that.
Asmodeus: Those are stock wheels. 17"
Old Jun 23, 2003 | 06:29 AM
D-5's Avatar
D-5
2003 E55
what is the factory spring pad setting? Front 4, Rear 3???
I think I also have spring pad #1 all around, but wouldn't this makes the car sit low in front, high in back?
Old Jun 23, 2003 | 10:52 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
i've got the sways installed and i gotta tell ya, NO MORE ROLLING!!! fewwww
Old Jun 23, 2003 | 01:43 PM
hinhin7's Avatar
MB
hahahaha...Im hoping the same too...
Ahmed, did you install the sway bars and the springs at the same time. I was just wondering which one has more effect in reducing the body roll. Eibach bars Vs H&R springs
Solihin
Old Jun 23, 2003 | 03:51 PM
Ahmed's Avatar
haha...
i installed the springs first, i kept the shocks stock cause didnt want to sacrifice comfort. Then i realised that although the car was more stable, body roll was still annoying. I use to get alot of understeer too. So after installing the Eibach bars, that problem just disappeared. Thank god!
Old Jun 23, 2003 | 06:22 PM
J Lucas's Avatar
Ahmed. your running aftermarket springs with the stock shocks? Hows the ride? Won't your shocks wear twice as fast since your lowered with factory shocks? I want to try H & R springs with OEM shocks so bad but I dont want to be changing my shocks once a year.
BTW, how much are the eibach sway bars?
haha...
Old Jun 23, 2003 | 07:57 PM
Brian_I.'s Avatar
w211 & w124
Really looks good! I want to do the same but not sure how it will affect the ride. I read a lot of varying opinions, so it's hard to tell what the real difference will be.
Old Jun 23, 2003 | 08:50 PM
hinhin7's Avatar
MB
I think it is around $450-500...
Old Jun 23, 2003 | 09:35 PM
Steph's Avatar
....I installed the H&R springs and Bilstein Sports on my 430 and was still not happy with the handling....although the "tightness" of the suspension had increased....the roll was still about the same......I felt the only benefit from installing the shocks and springs was when I dove into a turn or a long sweeping one. I then installed the front CLK55/Eibach sway and felt the difference right away........under more extreme cornering the car had a greater tendency to oversteer........after installing the rear sway, that sensation was neutralized...if I really liked to drive hard all the time and throw my car around corners....I would upgrade only the fronts and leave the rear stock. I can tell you this......my friends that would ride with me did not notice much after lowering the car; however, once I had the sways installed.....they have all said, "Dude, your car has no lean."
my .02 for what it's worth.
Old Jun 23, 2003 | 10:46 PM
hinhin7's Avatar
MB
hahahah... good for you Steph...
Ill be installing the eibach bars front and rear as soon as possible..
probably next week.
Old Jun 24, 2003 | 04:10 AM
Ahmed's Avatar
well, my car has done 90K and no problems as far as shocks are concerned. Maybe just the way i drive.. or just plain good luck!
I even upgraded my wheels to 18's and i do get rubbing when i have load in the car, otherwise no problems.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
