Instrument Cluster Change
Old Feb 13, 2012 | 11:56 AM
fullmetaljacket's Avatar
CLK 230 KOMPRESSOR
Can I change my 98 CLK 230 KOMPRESSOR Intrument Cluster/Speedo (with boring black speedo faces) from this...
to this white faced sporty looking speedos ...
http://www.ebay.com/itm/120818266892...ht_1308wt_1014
or this...
http://www.ebay.com/itm/150725942580...#ht_921wt_1014
or this...
http://www.ebay.com/itm/390386912535...#ht_500wt_1261
or this...
http://www.ebay.com/itm/380383147165...ht_2136wt_1247
Which would be the best fit for me? Plug and play I hope I have not taken out my speedo cluster yet to determine the connector configurations at the back. I figured some of you might have gone through the change or upgrade already...?
Hope you can share your experience. TIA!
Old Aug 20, 2012 | 04:18 PM
stubbs_peter's Avatar
CLK 2.3 Compresssor
You can change to white dial a lot cheaper if you go to this site, the kit is $19;
http://www.whitegauges.net/
You have to remove the instrument cluster and remove the clear plastic cover, but there are instructions in the kit. They also provide a fitting kit for $5
Regards,
Pete.
Old Aug 22, 2012 | 08:14 AM
DRfunjoo's Avatar
wow $19 is freakin' cheap bro! That's sick. what model would we choose however given that the w208 is not listed there? I'm sure another one would work if i'm not mistaken?
Old Aug 22, 2012 | 02:33 PM
CLK 2.3 Compresssor
Hi,
Yes the dials for a C230 99-00 will fit.
Regards,
Pete
