swaybar bushing
Old Mar 20, 2012 | 03:54 AM
VIPclk320's Avatar
CLK W208
swaybar bushing
has anyone used these bushings for their sway bars. Im thinking of using them for my H&R sway bars. I got a H&R sway bar for the rear a while ago and never installed it because i bought it from a friend and he lost the bushings. the bar is brand new but no bushing. so i started to look for bushings to install my rear sway bar and i came across these. now for the experets: i heard the clk 55 w208 came with 28mm front and 18mm rear sway bars, is this true? if so then i can jst order the bushings for the CLK55 because the H&Rs are that size as well. any guidence would be much appreciated.
Old Mar 21, 2012 | 08:44 PM
Ruination Fan's Avatar
02 CLK430
If I remember correctly the 55 is the same diameter as both Eibach and H&R, so in theory they should work for what you are looking to do
Old Mar 21, 2012 | 11:19 PM
VIPclk320's Avatar
CLK W208
Thank you very much, i was able to order the H&R bushings from Rodmillen motor sports in huntington beach which is a direct dealer of H&R. Thank you very much for the info now i know for the next set.
