Relay hardness installation, help me
Old Apr 11, 2012 | 10:38 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
Question Relay hardness installation, help me
im trying to install this.. but as we know the battery is in the back so where do i hook up the ground plug (black ) and the red (power wire) to??
i only need it for my high beam.
im very bad in electrical stuff and have no idea..
ty in advance
Old Apr 12, 2012 | 12:09 AM
VIPclk320's Avatar
CLK W208
The best ground connection inside the engine bay is under your windshield washer water resevore. Remove the black plastic knot on top of the water resevore and pull the resevore up and underneath you'll see a screw welded to the body and a bunch of brown wired attached to it via a knot, remove the knot put the ground wire between two of those wires and then tighten it back and that your ground. For the positive which is direct connect to your battery, there is a jumper terminal on your driver side front shock tower, it's a black plastic box, remove the cover on that small box and there are two wires inside that box they are both positive direct lines to the battery, either one you connect it to your ok they are both positive. Hope this helps.
Old Apr 12, 2012 | 12:16 AM
always at the rescue mister.
Ty so much aziz .....
Old Apr 12, 2012 | 02:50 PM
VIPclk320's Avatar
CLK W208
haha, no problem.
