Rear flex disc. Need info., Replaced front OK, how replace rear ???
Old May 2, 2012 | 09:56 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Rear flex disc. Need info., Replaced front OK. How replace rear ???
When replaced front flex disc, drive/propeller shaft slipped away a couple of inches, allowing for removal of disc.
Questions:
1. Does drive shaft at rear differential also slip away a couple of inches to allow removal of rear flex disc ?
2. Can rear flex disc be installed while front drive shaft and flex disc is still bolted together ?
Thanks.
