W208 Coupe 2 Broken Coil Springs
My 2001 CLK 230k Coupe went in for a service yesterday at a local garage as it was nearly due and had been making an awful clunking noise from front and rear of car turns out nsf coil spring and osr coil springs had broken along with the osf track rod and osf ball joint
So car is in with them until next tuesday been quoted £580 including parts and labour which i thought was very reasonable as all four coil springs are going to be replaced.
The only other downside is i have a Peugeot 107 1.0 litre thing as a courtesy car and of course its manual
after driving a Benz and automatics for a while its very hard to drive something so small.Has anyone else had to have all four replaced as i am interested to know how much you were charged?
Edit: £230 i think supply and fitted,
Yeah i requested they fit the Merc ones as you say the difference in price was minimal they said to me it was £15 per spring
Price seems right for two so double i would say for all four i think i have got a good deal in the end considering the other bits that needed doing.
I have to agree it does seem that it is more common and depending on where they break you might not have any trouble or noticeable difference in handling.
I certainly have not noticed a difference just a loud noise over certain bumps and lumps in the road. Surprising really i thought it would be really obvious.
I wonder how mnay people are driving around with similar problems but are not aware of it. Quite a few i imagine
Just to let you know the springs are not expensive, but you are paying mostly for labour im afraid.
Just make sure the garage does an alignment after the front end is touched with new springs, track rod end etc. As the car may have been aligned with broken springs and it only needs to be out by 0.5mm to wear your tyres out. If the garage knows this they should do the alignement as part of the work, its well worth asking.
I also learnt the hard way on another car had patten springs fitted and it was way high and never settled as I was told, I should have taken it back but sold it soon after, I think most people realise a springs gone only when they fail the mot, they must snap at the top,
