Question for CLK OWNER......
Old Jul 11, 2003 | 11:23 PM
clk_klass's Avatar
02 clk320
My 02' clk320....... I got a rocking (rough idle) when the car is at park position or stop at the red light. it's not a lot but u can feel it rocking. Brough it to the dealer they told me all clk have that rocking during idle..but it doesn't feel right....even a Honda civic doesn't have that problem... so, I wonder it just my clk or anyone els have the same problem....??
thanks
Old Jul 12, 2003 | 01:01 AM
LAMAY123's Avatar
A 2-Seater Roaster & A 4-Door AMG & 2008 S550
Don't have that problem yet....(knocking on wood as I am typing)
Old Jul 12, 2003 | 01:54 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
myself and Josh had a similar if not the same problem.... my route, I had the dealer adjust the idle RPM, and that helped a little.
Josh on the other hand, at the recommendation of Ben, got some fuel injection cleaner, and that helped Josh in his scenario. I believe Ben suggested Red Line injection cleaner....
By the way, Ben, could this rough idle be caused by using cheap fuel? or for that matter, non-premium octane fuels?
Old Jul 12, 2003 | 02:21 AM
clk_klass's Avatar
02 clk320
I bough my brand new it happen since then..and I always use super unlead (91)...this is my second times brough it in....the first time they said the engine mount problem. replaced the engine mount problem still there..second time they said they check, no error code and no miss firing found with the computer system and end up they told me all clk are the same with rough idle. so, I just want verify with all the CLK owners in forum is this true. I might end up going back for the thirt time....
Old Jul 12, 2003 | 01:10 PM
Martin's Avatar
CLK320, Carrera S
The dealer is incorrect.
You may need a new Mass Airflow Sensor.
Martin
Old Jul 18, 2003 | 02:04 AM
xyzpl's Avatar
S60R, ML320, W211/E350
Had the same problem, it was the MAS. After it was replaced, idles fine now.
Old Jul 18, 2003 | 02:58 AM
clk_klass's Avatar
02 clk320
Thanks guys...I'll give it another try...
Old Jul 18, 2003 | 03:34 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
fuel injection cleaner...check the sparkplugs...MAS
can't be worse than my dad's 96 XJ12 which the tech has to adjust every thing by hand. Say hello to the 30 yr old V12...
mmgrad, nice new sig
Old Jul 18, 2003 | 09:36 AM
mmgrad's Avatar
Thanks... it may look nice, but the car doesn't compare to your C32...
Old Jul 18, 2003 | 10:32 AM
clarkspark's Avatar
99' CLK 320 Coupe
Had the same problem here. Heck just yesterday I was contemplating it. It felt to me like it was the spark plugs, but just in case I just so happened to let the gas run out til the gas light came on. I then added some Fuel injector cleaner and WALA! Good as new.......for me.
Old Aug 1, 2003 | 03:20 AM
clk_klass's Avatar
02 clk320
today I brough in my clk to the dealership
again, they still can't find the problem (rough idle) ...I suggested to them the Mass Air Sensor...they said they check but the sensor is okay....
Old Aug 1, 2003 | 03:24 AM
mmgrad's Avatar
Re: .
Have you tried the fuel injection cleaner solution??? Give that a try and report back... it won't hurt and its not that expensive...
