1 engine and 1 radio question
Old Aug 5, 2012 | 04:22 PM
rsparso's Avatar
02 CLK 55AMG
So, I'm still poking around my new to me car and I've a couple of questions I'd appreciate some help with.
First is radio related; I've got a hand written code for the radio, is there a way to check it's correct without removing power from the radio and hoping ?
Second, is there a way to confirm that an AMG engine is in the car, (it has AMG badging on the trunk lid), from an external examination ? I read that someone thought the only the AMG had a small cooler on the side of the oil filter housing. Is that correct and should there be any other tell tale signs ?
Old Aug 5, 2012 | 04:59 PM
IBelieve's Avatar
2008 E320 Bluetec
As for the engine, that's a good question.
When I was buying mine, I took it for a test drive and timed it from 0-60.
5 seconds flat. With close to 120,000 miles on it, that was all I needed!
Old Aug 6, 2012 | 04:08 AM
Chappy's Avatar
AMG
Your VIN should help confirm if your car is authentic. A visit to the draler can help confirm the radio code.
Old Aug 6, 2012 | 06:10 AM
rsparso's Avatar
02 CLK 55AMG
Thank, I'll see if they'll verify it.
Old Aug 6, 2012 | 10:19 AM
tomtomtomtom's Avatar
02clk55///2010GLK350
....any time you have radio code issue, dealer will give it to you in person..not over phone. They will also verify if car is amg from their vin database.
Old Aug 6, 2012 | 05:00 PM
rsparso's Avatar
02 CLK 55AMG
Thanks, looks like a hike to the dealer's called for !
Old Aug 6, 2012 | 11:12 PM
dlbehrns's Avatar
99CLK320,
Keep your guard up with the stealership.
