mpg
Old Aug 7, 2012 | 03:23 PM
cdc3212000's Avatar
mercedes clk200 kompressor
mpg
I'm only getting 17 to 24 mpg could it be the maf sensor how easy it to clean or replace thanks for the help
Old Aug 7, 2012 | 05:38 PM
mint's Avatar
2013 FIAT Abarth 500
Any other symptoms? Rough idle, slight hesitation during acceleration?
It's possible the MAF could be dirty. Pretty easy to clean and just as easy to replace. Use the search function as there's several threads.
Old Aug 8, 2012 | 03:29 AM
cdc3212000's Avatar
mpg
yes there is a rough idle and slight hesitation during acceleration but no lights on the dash.
how easy is it to remove??
Old Aug 8, 2012 | 03:37 PM
mint's Avatar
Search "maf removal."
I know there's probably at least 20 threads that tell you how to do it.
Old Aug 10, 2012 | 03:34 PM
cdc3212000's Avatar
mpg
i've found it removed and cleaned it but no change to the running of the engine, so going to have diagnostic test done!
Old Aug 13, 2012 | 11:02 PM
Pancho's Avatar
2000 CLK430 Cabriolet
I have original MAF, 12 Yrs.
Clean it every few years.
Not a prob.
Here's a link to an instructional I put together some while ago.
http://www.benzworld.org/forums/w208...ir-filter.html
Old Aug 14, 2012 | 07:30 AM
IBelieve's Avatar
2008 E320 Bluetec
Great tutorial Pancho, Thanks so much.
I'm going to do both ASAP.
Old Sep 5, 2012 | 11:03 AM
cdc3212000's Avatar
mpg
the car has been to local garage, they replaced the up stream O2 sensor it is now running as it should 30 - 35 mpg.
Old Sep 5, 2012 | 06:31 PM
dlbehrns's Avatar
99CLK320,
R U in Europe? The size of your gallon is probably different than ours in NA.
Old Sep 5, 2012 | 08:42 PM
itscard0man's Avatar
01 clk55
[QUOTE=cdc3212000;5346600]the car has been to local garage, they replaced the up stream O2 sensor it is now running as it should 30 - 35 mpg.[/QUOTE ] daaaamn , i get like 11-20mpg in my amg !!!! maybe
