2002 CLK 430 Telephone connection
Old Aug 16, 2012 | 02:58 PM
Korver's Avatar
2002 CLK 430
I just bought this car, and I was wondering how do i enable the option.
There might be a part that I may have to buy in order for this telephone hook up to work.
What is the part name/number?
How do I check if I have this part?
Old Aug 21, 2012 | 03:30 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
It's an easy solution but not sure you'll like the results. I use the bluetooth puck and connect Iphone to the factory comand HU. Incoming voice is crystal but outgoing I hear is not so good. If you have the factory system you will need either the V60 cradle and puck or the puck with tail combo. You will also need to check your PSE to make sure you have one with a "blue" lable. If not you will need to hunt one of those down also. Honestly your probably better off with a Parrot solution. They are quite inexpensive and good sound quality.
