Newbie Question about Secondary Air Pump
Hi all
I recently bought a 1999 CLK320 with 160 000km on it, but it is pulling a P0410 Secondary Air System code.
My mechanic said it is mostly likely the airpump, but i've been doing some reading and I figure i should try and replace the relay first before buying an airpump.
In regards to that, would a faulty air pump cause a rough idle while cold? My car will idle very rough and rpms drop slightly when stopped at a light for example.
I know there are alot of threads covering this, but i couldn't find if the rough idle is caused by the airpump as well.
I appreciate any help you guys can provide.
Varun.
Varun.
