W208 clk55 Clogged windshild drain..How to get at it?
Once the cover's off you can just use a vacuum hose to clear out all the muck and leaves. I also stuck it in the cavities in the corner of the engine bay at the same time (where the drain goes into).
There also supposed to be a filter that sits under the cowl intake vents which on mine has almost completely disintegrated, so I got my local dealer to order it in (only a few pounds/dollars).
As for the ducts under the carpets there are the heating ducts for the rear seats and there are also some wiring ducts that run across the car from the centre console and along the sills. The clips for the wiring duct covers are similar to the windshield drain cover except much easier to access and the plastic is thinner and more pliable I found so can unclip them by hand fairly easily. The rear passenger heating ducts exit out under the front seats and are connected up to the heater matrix behind the centre console. You have to remove the seats to get at these but once you do they're held down by just one screw at the inside rear of the duct then once this is out press down near the front end of the duct, in the middle on either side of the chassis rail for the front seat mounting points. What you're trying to do is squash the duct enough to disengage that piece from the rest of the ducting leading from the centre console and slide it under the chassis rail towards the back of the car. If you don't do that you'll find you can move the duct from side to side but it won't come free. You have to remove the these ducts to get the rear carpet out (along with many other bits)
For yours and other people's benefit, as I found only bits and pieces on here and other forums on how to remove the rear carpet, I've summarised the main steps and can give more detailed instructions if anyone's interested:
- Remove the front seats
- Remove the door sill covers/scuff plates
- Loosen the footwell side trim panels
- Lift out the front carpet(s) (I only removed the passenger side as the driver's footwell wasn't flooded)
- Unscrew the foot plate protecting a couple of electronics units
- Remove the rear seat bench
- Remove the seatbelt lower mounting point(s)
- Loosen the rear quarter panel trims (bottom and side edges are enough to get the carpet out)
- Remove the lower covers below the glovebox and instrument cluster
- Remove the passenger and driver footwell air vents
- Remove the centre console (which includes removing the radio, aircon and various switches)
- Remove the underseat air ducts
- Hey presto you can now remove the rear carpet and dry out all the water
Tools you need are various size hex and torx sockets, ratchets and extension bars, star screwdrivers, plastic pry tools and BBQ tongs!
When the panel below the glovebox is off you can remove the heater box cover to drain the water out if you haven't already.
Hope that helps.
Hope that helps.
