Convertible won't retract.. Checked fuses, what next?
Basically nothing happens when you press the button to retract the top. I checked the fuses and they all looked fine, so I was wondering what to check next.
There is no noise at all when pressing the retract button.
What do you thing would be the next check?
Thanks!
trunk shut and luggage cover extended, right? check the relay first since that's the most common thing to go.
I wouldn't think that a dying pump, leaking cylinder, or low hydro fluid would be the issue. It's not making any noise or even attempting to retract- so I'd say it's an electrical fault for sure..
Where are the relays? How do you test them? Just have to swap in a known working one to rule out the old one?
THANKS!
The relay for the pump is right next to the pump. It's a bit painful to get access to the pump. Not difficult to do, but requires removal of a number of bolts and clips. You can check the fluid level at the same time. If the pump's electric motor hasn't blown any 40A fuses yet, then it is probably okay.
Here is a good DIY that includes access to the pump: http://www.tophydraulicsinc.com/W208...eplacement.pdf
Klaus
Klaus
Thanks for the very helpful pdf!
I'll be using it to help diagnose, so thanks very much!
