Brakes and the wear lite
2002 clk430
This might sound stupid but what lite is the brake pad wear sensor? i know my pads are getting low but the only lites i have gotten are the abs-esp lites. Also if anyone has a instructional on changing the rear pads would be appreciated.
2000 CLK430 Cabriolet
The rears are the same apparatuses as the fronts. Only significant difference would be if you wanted to do maintenance on the E-brake. Otherwise, an instructional on the fronts should provide about 95% of the info needed. I can link you to one, if you want.
