Check engine light came on.
Old Aug 1, 2003 | 05:07 PM
cl_kruisin's Avatar
2000 CLK430 & 2000 Expedition on 22's
Today, while I was driving my 430, I noticed the check engine light was on. It's running fine, was just serviced. Any suggestions?
Old Aug 1, 2003 | 05:23 PM
khans's Avatar
is your gas cap on properly?
Old Aug 1, 2003 | 06:39 PM
Brian_I.'s Avatar
w211 & w124
Definitely check the gas cap first. I had the same problem and it was my O2 sensors, the two that come after the Cat. converter, replaced under warranty, whew.
I also bought an OBDII tester and figured out the problem for myself. That way I'd know if the dealership tries to me.
I have the tester if you want to borrow it, although I live in LA.
Old Aug 2, 2003 | 02:28 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
yeah, I'd check the gas cap first... and if it seems to have been not tight... retighten it and after a few starts, the light should go off if that is the problem.
other than that, the only option is to take it to the dealer unless you want to tinker with it and try and fix yourself. in which case, you would need to be like brian and get an OBDII tester to find the fault and repair it yourself...
Old Aug 4, 2003 | 01:52 AM
cl_kruisin's Avatar
I checked the gas cap and unfortunately that was not the problem. Are there any other simple things that might cause the check engine light to come on? If not, I'll just take it to the dealer and get it warranteed, I need new dash lights anyways
Old Aug 4, 2003 | 08:00 AM
D-5's Avatar
D-5
2003 E55
I bet it's the O2 sensor, I had the same problem last month, replaced under warranty. Yesterday, my fuel gauge doesn't work, guess I need to visit my dealer, AGAIN....
Old Aug 9, 2003 | 12:08 AM
Michigander's Avatar
99 CLK 320
Mine came on just before I bought it. Had seller take to the dealer. "Faulty air valve sensor." $400 parts and labor.
Old Aug 9, 2003 | 01:00 PM
cl_kruisin's Avatar
Well after I adjusted the gas cap, the light went off two days later.
Old Aug 10, 2003 | 03:10 AM
mmgrad's Avatar
i knew it... glad to see that it was nothing serious
Old Aug 12, 2003 | 01:30 AM
charliev68's Avatar
2000 CLK430
filling it up with too much gas will also cause it to happen.
it happened to me and i freaked.
16.4 is the max capacity according to the tank content window.
if you top it off too much the amount will stay at 16.4 for about 20 miles. after you kill some gas from driving and the content goes away the light will turn off.
