E-Brake Pedal Bracket
Old Jan 10, 2013 | 04:00 PM
njgilligan's Avatar
2001 CLK55
I recently noticed the e-brake light on my dash wasn't going off even when I pulled the brake release. Turns out the bracket that holds the sensor switch broke. It's a cast metal piece that holds the e-brake pedal and sensor switch, but I can't figure out what the p/n is to order a new one. Can anyone help out?
Old Jan 11, 2013 | 03:51 PM
njgilligan's Avatar
2001 CLK55
nevermind, it seems the entire parking brake assembly can be found on eBay for under $40, so I'll just replace the whole thing!
FYI, I'm not sure, but accoudring to this document:
http://mercedesml.info/ParkingBrake.pdf
It seems to be an identical part for the following models: 129, 140, 163, 202, 203, 208, 209, 210, 211, 215, 220, 230, 240
In case you're looking, the PN is: 220 420 03 12
