retrofit command
Old Jan 17, 2013 | 12:42 AM
BK627's Avatar
2007 CLK 350 Cab
retrofit command
I really want to install a command system in my 2000 clk 430
has anyone here done this? i need to know where i can buy all the needed material for the installation. I can buy the command unit by itself for a really good price i just do not know how hard it will be to connect everything. i also do not know what parts are needed.
any help would be appreciated
Old Jan 18, 2013 | 02:49 PM
Scott Simoncic's Avatar
2001 CLK55 AMG
Search dude, very well covered topic. It's been done, it's not plug and play, you're honestly better off going aftermarket double-din.... But it is possible if you really want to. Requires the correct command unit, a conversion wire harness that's pretty pricey, cutting the center divider out of the double din slot.
