W208 window/mirror/trunk release
W208 2.3K Coupe
window/mirror/trunk release not working from interior switches, trunk and windows work ok from fob outside the car.
Any ideas? have checked all the fuses etc
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
W208 2.3K Coupe
That module
Hi Vejay,
yes it is, you replace the whole panel assembly which is an ECU, usually damaged by charging the battery without disconnecting it, or jump starting.
Dead simple job, i fitted mine (used, from a Breakers yard for £2.00) in about 10 minutes.
It is plug & Play, and no troubles since!
Dont forget to synchronise the windows for the one shot function.
Let me know how you got on,
Regards
John
Regards
John
