Key is out of juice... how do I change the battery?
Old Mar 1, 2002 | 03:16 PM
A.Emgee's Avatar
My key needs a battery change. Anyone have experience changing it themselves?
Thanks in advance.
Old Mar 1, 2002 | 03:54 PM
jkelley's Avatar
2001 MB CLK55
[list=1][*]Remove the mechanical key from your smart key[*]Inside the slot you just exposed by removing the mechanical key, you'll see a gray piece of plastic.[*]Hold your smart key with the panic button facing you and down[*]Take your mechanical key and press the gray plastic piece to the left.[*]With the gray plastic piece moved left (it's spring loaded) get your thumbnail into the seam at the top of your smartkey[*]Slide the removable section out, and viola - there is your battery![/list=1]
Old Mar 1, 2002 | 06:21 PM
A.Emgee's Avatar
Thanks! Now where can I find batteries like that?
Old Mar 2, 2002 | 04:48 AM
SteveZ's Avatar
Take them out, then go to radio shack and show it to them.
