Introducing a New Old Car! with some little problems
I've just bought a W208 1999 CLK430 with ONLY 9660Km! (that's less than 6000 miles for you folks!) it still smells like dealership.
The car sat in a garage for many years, only service @ Mercedes was done in 2010 (oil and battery change).
I have changed differential oil, engine oil and filter, battery. reset the transmission, wiper blade.
Car passed Aircare inspection (Canada) and runs extremely well, I had the fuel gauge not working well and a code P0450 (Evap sensor) that pops up and I hope is the fuel cap and the fact that has been sitting so long!
Any suggestion from the experts? transmission fluid seems to be good, no leaks, I was thinking about changing the brake fluid.
Ill post pictures soon since really this car is unique! and I love it.
the following is a copy/paste: Vehicles using Extended Life antifreezes should be changed in about 50,000 miles or 4 years to prevent system damage and radiators and heater cores from plugging up.
WATER CONCENTRATION/ANTIFREEZE CONCENTRATION SHOULD BE AT LEAST 50%
The modern antifreeze, however, does much more. It provides year-round protection of the cooling system: It prevents freeze up in winter and boilover in summer (especially in cars with air conditioning). It provides protection from rust and corrosion and does not harm rubber hoses and plastics.
A desirable antifreeze should not corrode metal parts, attack rubber, become viscous at low temperatures, or evaporate readily at the ordinary engine operating temperature. It should be chemically stable, a good conductor of heat, and a poor conductor of electricity (which causes electrolysis).
The performance requirements of automobile antifreeze became more severe during the 1980's. The reduction of the overall mass of vehicles to improve fuel economy entailed extensive use of light materials such as aluminum and plastics for the construction of engine and cooling system parts.
The volume of antifreeze used was also drastically reduced to further reduce weight, subjecting the antifreeze to high rates of flow, high temperatures and significant metal-to-coolant heat fluxes. Today's smaller, efficient and powerful engines dissipate more heat, requiring that the antifreeze keep the heat exchange surfaces in clean condition. In addition, corrosion, which in itself is of concern, can also result in heavy corrosion deposits that impedes heat transfer.
What is Electrolysis?
As the additives in your coolant that keep it neutralized become depleted over time the coolant actually develops an electric charge from passing over dissimilar metals. You can even measure this voltage with a voltmeter! This small electric current removes metal from engine surfaces leaving large pits or holes and can eventually eat entirely through a component. It can also weld bolts and fittings to the engine and components.
This can be caused by coolant that is too old or antifreeze mixtures that are not close to 50%.
A Digital Multi-meter can be used to test for this.
Attach the DMM ground probe to the negative battery post.
Insert the tip of the positive probe into the coolant and observe the reading.
OK - less than .10 volts.
Bad - anything above .20 volts.
Electrolysis destroyed this headgasket. (picture) It started leaking from a coolant passage to the outside of the engine after the material was eaten away.
