CLK430 A/C Fan Operation?
2000 CLK430, 2012 BMW X5 3.5d
When the AC is running should the front electric fans be constantly running or is is dependent on temperatures? With mine it will cycle on/off on the first speed only when temps pick-up. The will run continuously when the outside temps are hot - or the engine temp is hot. Is this normal or should the fan run continuously whenever the compressor is engaged?
