Auto Dim Side and Rear Mirror Issues
For the Left Side Mirror it appears that the Electorchromtic(?) fluid has leaked partially out. The glass is not cracked but it does appear that the outer rim is slightly cracked. After looking at the cost (WHOLEY MOLEY) of a replacement I was wondering if it is better to just loose the auto dim function and replace it with just one having just the heated function. In an effort to see if this is feasible I reviewed the wiring connection and it looks like the Auto Dim/Heated Mirror uses a plug type connector with 4 wires while the replacement heated only mirror uses a two prone spade type connection. Given this does anyone know which of the two wires controls the heat vs. the Auto Dim. and I do decide to go this route am I going to be impacting the way the interior rear mirror functions and or result in a code being thrown?
Now for the Interior Auto Dim mirror. This item is acting strange in that it remains in Auto Dim mode all of the time with the exception when the engine is off or when running but in Reverse. I am assuming the Off when reverse is correct however being on in Drive and in FULL SUN is not correct. In thinking that the side mirror issue may have some impact on this I removed the side mirror and then tested it but the results are the same.
Any assistance or thoughts would be greatly appreciated.
Robert
As for the internal mirror , i not sure.
I don't remember any difficulty in doing this it was really obvious when I took the mirror off so you should have no problems.
PS to remove the glass, you tilt the glass all the way down and in, then to expose a small metal sprung wire that sits in a groove at the top. Use a small flat head screw driver to push this over the lip at the 12 0'clock position, and the mirror will come off its round mount. You will see the two spade connector wires when you do this.
I checked Ebay and found this...
http://www.ebay.co.uk/sch/i.html?_od...irror&_sacat=0
TIP:
When you buy your glass it can either come with just the glass or mounted on the black plastic backing. From memory I just bought the glass and then pealed of the old broken glass from the OEM black plastic backing, then stick the new heated mirror, which already has the sticky backing supplied, to the original backing , to ensure you are going to get a good fit.
