Spring Pad Question and What Wing is this?
Old Sep 2, 2003 | 02:50 AM
CLK430ROB's Avatar
Hey guys -
I was wondering if any of you know the correct part number for Spring pads #1? This is what I got from benzworld:
210 321 0184 5mm
Correct?
Also, what kind of Wing is this? I believe is MH-Dezent, but I cannot find it on the web Thanks!
Attached Thumbnails Spring Pad Question and What Wing is this?-clk-dtm-vm-08.jpg
Old Sep 2, 2003 | 03:13 AM
frappe's Avatar
02 CLK 430 blk/blk
I think since it's for CLK, the first three number should be 208 instead of 210.
Old Sep 2, 2003 | 10:56 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
no, not really...
there is no 1 Dot spring pad for the CLK, so yes, you would use a W210 pad. As long as that is a 1 dot pad, it will work perfectly fine.
I can dig up my receipt to check the part number when I get back home if you are interested, but yes, it is a part that starts with # 210....
Old Sep 2, 2003 | 11:06 AM
mmgrad's Avatar
oh yeah, and in terms of that spoiler, yea, it is a MH-Dezent/Expression spoiler... and the center piece is supposedly a Carbon Fibre piece...
There was a previous discussion on the forum about the spoiler, and I think the outcome was that the spoiler wasn't really produced for resale (or no longer produced).
search the forum for more exact results...
Old Sep 2, 2003 | 11:30 AM
Benzoxtc's Avatar
2002 CLK 430/2002 325i
Spring pad part numbers
here is the list of the spring pad for your car.(spring isolator)
Front
5mm ----- pad #1 210 321 01 84
9mm ----- pad #2 210 321 02 84
13mm ---- pad #3 210 321 03 84
17mm ---- pad #4 210 321 04 84
23mm ---- pad #5 210 321 05 84
Rear
5mm ----- pad #1 210 325 01 84
9mm ----- pad #2 210 325 02 84
13mm ---- pad #3 210 325 03 84
17mm ---- pad #4 210 325 04 84
210 - Identifies chassis
321 Identifies front
325 Identifies Rear
0X - Designates the thickness
CLK 430 current set up F-#4, R-#3
CLK 55 current set up F-#3, R-#2
Old Sep 2, 2003 | 01:34 PM
Mach430's Avatar
CLK320 stock setup 3/3
But these numbers (including 430/55) vary at times.
Old Sep 2, 2003 | 02:22 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
There's no 1-dot spring pad for the CLK? You're using one, aren't you? So I think there is one.
CLK spring pads start with W210, because that's what the CLK uses (and the 1997+ W202).
-s-
Old Sep 2, 2003 | 02:25 PM
scorchie's Avatar
That's definitely NOT how it works. If you go through the parts on the CLK, you'll see that the numbers start with LOTS of different prefixes.... 202... 210... 201... 124... 140... 129... 112 or 113 engine parts... maybe even some 203 or 209 parts (believe it or not... check the ABS or ESP units on a 2002 CLK). Then there are the 001, 003, 033, 016 parts. And more!
-s-
Old Sep 2, 2003 | 06:16 PM
nickv's Avatar
Used to be a CLK430
So a dumb question, to lower the car, I should buy the 5mm ones, right?? Will my ride suffer?
Old Sep 2, 2003 | 06:51 PM
mmgrad's Avatar
-s-
well, you know what i mean...
if you go to the part department and ask for a 1 dot pad for a CLK, they will say, smallest they have is a 2 dot.
but, these pads are interchangable between various chassis, you can use the one that is techinically assigned to the E-class.
Nick, your 430 comes with 4 dot front, 3 dot rear (most likely), so anything less will lower your car. the thinner the pad, the lower it will be...
ride will be a little harsher, but not by a whole lot... i'm on 1 dot pads, and i still have all my teeth...
Old Sep 2, 2003 | 10:58 PM
D-5's Avatar
D-5
2003 E55
I think I have #1 spring pads all around on mine. Is this the proper setup? Should I have #2 front and #1 rear?
Old Sep 2, 2003 | 11:47 PM
mmgrad's Avatar
if you want to follow the factory settings, then you should have the fronts as 1 dot higher than the rears...
but, i don't think there would be any adverse effect of having #1 pads all around...
Old Sep 3, 2003 | 04:02 AM
scorchie's Avatar
That's not true. There is a formula used (it's in the EPC) that lists all the options available on the car. To find which pads and which springs were fitted to each car, each option code is assigned a "point value". If you take all the point values for each option installed in a given car, this total value is compared with a chart which lists which spring and which spring shim (called "pads" here) is used.
My CLK came from the factory with #2 all around. Not "front 1 dot higher than the rear".
-s-
Old Sep 3, 2003 | 11:07 AM
mmgrad's Avatar
-s-
no argument there... i know some CLK have been shipped with diff spring pad sizes, but I was just saying, typically, the majority seems to be getting 4/3 as a standard setup because the majority of CLKs are sold with relatively the same list of options.
I wonder what kind of added options would warrant different pad sizes?
Old Sep 3, 2003 | 03:09 PM
scorchie's Avatar
Pretty much... nearly all of them! I can print the list out if you're interested. But Bose adds a few points... xenons add a few points...phone system adds a few points... and so on.
-s-
Old Sep 3, 2003 | 05:20 PM
mmgrad's Avatar
-s-
very interesting... each of those options don't weight much in itself, but i guess added together, it can weight a few extra pounds...
no need for the list, but thanks for the offer.
Old Sep 3, 2003 | 06:12 PM
CLK430ROB's Avatar
Thanks for all the replies and insights
now... the final questions... Where do I get a set other than going to Mercedes? I want #1 all around for my 01 CLK430.
Thanks,
Rob
Old Sep 3, 2003 | 07:02 PM
mmgrad's Avatar
Re: Thanks for all the replies and insights
Thanks,
Rob
how come you don't want to go to the dealer? Its only $6.xx each at the dealer... aftermarket places will charge you about the same amount....
Old Sep 3, 2003 | 09:56 PM
scorchie's Avatar
Thanks,
Rob
Rob, you've seen them at my place... I think we're out of #1 right now though.
-s-
Old Sep 4, 2003 | 01:29 AM
D-5's Avatar
D-5
2003 E55
Does having dot 1 pads all around makes the car sit lower in front, higher in the rear?
Old Sep 4, 2003 | 02:05 AM
mmgrad's Avatar
depends on how you change the pads.. if you have 1 dot in the front, and 5 dot in the rear, then yes, it will be higher in the rear
Old Sep 4, 2003 | 03:05 AM
CLK430ROB's Avatar
-s-
Scorchie! -
I have!? Who are you?! LOL!
Where can I order some ASAP tho!
- Rob
Old Sep 4, 2003 | 04:54 AM
scorchie's Avatar
Re: Re: Thanks for all the replies and insights
Scorchie! -
- Rob
You know... where you got your car lowered!
-s-
Old Sep 7, 2003 | 10:15 PM
CLK430ROB's Avatar
Re: Re: Re: Thanks for all the replies and insights
-s-
ahhh...yeah!! :P... didn't know your handle was Scorchie on here.. HAHA.
Hey, can get me the #1 pads for front and back of my CLK? I remember u guys change my pads for free if needed :P
About to get some new rims soon, so my Carlsson's 2/5 brilliants are for sale. thinking of bringing it down just a tad more.....
let me know guys.
Rob
Old Sep 8, 2003 | 02:07 AM
scorchie's Avatar
Re: Re: Re: Re: Thanks for all the replies and insights
let me know guys.
Rob
I'm out of #1 but I will have them the end of this week. Will keep you posted.
-s-
