Comand 2.0 no sound after restarting
Old Jun 27, 2013 | 03:29 AM
Daniel Hilli's Avatar
Clk 320 sport 1998
Hello,
Here´s the story:
1. I connected aux, worked fine
2. I bought a ground zero active bass, put it in the trunk, connected remote to +12v, connected + to + and ground to a bolt.
3. I realized I had wired the remote wrong, so I connected it to "antenna" instead. before I did this the bass was always on (of course), also I had to re-ground the sub, because the first bolt i grounded it to resulted in abs, bas etc etc going offline (wtf?)
4. after I regrounded and switched the remote cable to antenna, no problem… until….
5. This is what happens, I can drive for 200km, stop for some coffee, start the car, the comand 2.0 comes on… but no sound, not a whizz nothing. completely silent. I have tried to have comand turned off while driving, it comes on, but no sound. however, if I leave the car off for 30minutes or so Comand will start and play as before..
6. I have also tried unplugging everything when it "dies" on me, it didnt come on after re-plugging everything. although it did start playing after only 10 minutes..
Conclusion: I am wondering if this has anything to to with comand overheating? also it started doing this AFTER i regrounded and connected the ground zero (it is an active bass) altogether.. it has never done anything like this before.
If you´ve heard about an issue similar to this before and/or know what could be causing this, please reply.
Thanks for any ideas and/or thoughts!
Regards,
Daniel
Old Jun 27, 2013 | 06:32 AM
cindyclk's Avatar
I had a Euro command installed by SteveNL i get the same issue about 1/month. I correct by simply turning off car and restarting. Turning off command does not correct. Never explored cause because of ease to correct ad infrequency.
