convertible problem.i cant down it.but can up
moves at all if roof is up position..beside, if i press to trunk button
For top operation, We need the luggage protector closed, trunk closed and headrest down.
When servicing the hydraulic pump use only Mercedes approved suspension/soft top fluids, A trip to the dealer or a FEBI equivalent hydraulic oil. I prefer MB fluids.
Fuses, The main fuse boxes for the soft top are in the trunk and under the hood near the drivers hinge. They are referred to as SAMS signal acquisition module as well, on e-bay (relay). go figure. Check all fuses, my car has 4 boxes.
Others are reporting lock failures but the slow blink is a trunk interlock or fuse issue. (seemingly).
Hope this helps,
Gator
Headrest function is knowledge of a healthy pump which is a plus. The trunk switch intermittent bothers me as something is loose or failing.
Most of these cars key or manual trunk opening mechanics freeze up from lack of use. The trunk electro latch has micro switches built in as well.
The possibilities are limits in the headrest down switch. (under and behind the rear seat). or trunk. There is more to check though.
Chens find was incredibly rare and I would quote it I knew how he found it but the manual bleed screw is used to open or close the top by hand in an emergency or service event.
Try Chens first and report,
Cheers, Gator
