Soft top cables
Old Aug 11, 2013 | 09:15 PM
lawrdent's Avatar
clk 430 cabriolet
Soft top cables
I have been told on this forum that the cables that stop the top from banging down usually break. Mine have for awhile now and finally ready to fix them. I have searched this forum but can not find any instructions or pics on this. If someone can guide me in the right direction before I accidentally tear the top I would appreciate it.
Old Aug 12, 2013 | 01:13 PM
BK627's Avatar
2007 CLK 350 Cab
http://www.benzworld.org/forums/w208...fixed-1-a.html
Old Aug 12, 2013 | 02:08 PM
lawrdent's Avatar
clk 430 cabriolet
Thanks for the response and looks like an excellent thread with nice pics. Will try it next weekend.
Old Aug 14, 2013 | 11:09 AM
BK627's Avatar
2007 CLK 350 Cab
If you follow that thread you should be able to fix your cable tops without having to replace them. I replaced mine last year when i got the car and one of them snapped again a few weeks ago.
I don't have any pictures on how i fixed it. but i can tell you what i did.
first thing i did was remove the black plastic cover/clip that the cable sits in. I then passed the cable through the hole on the metal bar. I took a thick sized bolt drilled a hole through it, i had one nut on top of the hole and one underneath i passed the wire through the hole and tightened the nuts nice and tight.
The top works perfectly and better then ever.
