Backseat removal on CLK 320
Re: Backseat removal on CLK 320
Originally posted by PastorOfMuppets
How does one go about removing the backseat on a CLK 320? Are there certain latches I must open?
search the forum and you should find it...
Its kind of hard to find the release for the seat. There are two releases one on each side of the seat. If you look at the front of the seat at the part between the seat and the carpet you'll see a indendatation on each side. You can also feel around with your fingers under the seat. Look for a groove that leads towards the back of the seat about 3 inches in you will fell a latch. You need to use a screw driver to find it and then push it back. It's approximatley 8 inches from the end of the seat. It took me a while to get it but once you find the first one its easy. After that the rest of the seat comes out easily.
