P0120 Falut Code HELP!
Old Aug 15, 2013 | 12:09 PM
mauricekan's Avatar
clk320
My W208 CLK320 was in LIMP mode one day when starting up the engine.
No matter how hard to step on the fuel pedal, the rev only run up to around 2000rpm and the car only can drive at around 10km/h.
ESP Visit Workshop comes up on dashboard too.
I have a check with OBDII and P0120 ( Throttle/Pedal position sensor/ Switch A circuit ) Fault code.
I have tried to clean all the harness connecting th Pedal position sensor and the throttle Body. Even I have replaced a new Pedal Position Sensor with cost me around $100. The situation remains the same. ( I have cleaned the harness connecting to the sensors and the Throttle Body too)
I am wondering what should I replace next? The Throttle Body? or something else I missed?
Old Aug 17, 2013 | 07:35 AM
chris.otas's Avatar
CLK 320 2005
you should check and make sure non of the wires connected to actuator is damaged or cut. cus that happened to me months ago and it was mouse that ate the actuator cable.lol
Old Aug 17, 2013 | 09:20 AM
mauricekan's Avatar
clk320
Thanks for reply.
Problem solved since I have replaced a new Bosch Throttle Body. I think the old one ruined.
Old Aug 20, 2013 | 04:59 AM
chris.otas's Avatar
CLK 320 2005
alright mate. good to know.
