Broken Door Handle
Old Oct 9, 2013 | 03:58 AM
wtc911's Avatar
1999 W208 CLK230
Broken Door Handle
Hi friends - both my 1999 W208 CLK230 door handles (right and left) are broken (see the part of door handle circled in red) - do I need to replace the whole door card or are there individual parts for them that I can purchase i.e., the handle bracket and cover. The pic sample is exactly like mine minus the handle...Thank you for your advise.
Old Oct 10, 2013 | 08:05 AM
Serndipity's Avatar
2001 CLK320 Cabrio
The Pull Handle your show is available (see enclosed info.).
Attached Thumbnails Broken Door Handle-door.jpg   Broken Door Handle-door1.jpg
Old Oct 12, 2013 | 03:44 AM
wtc911's Avatar
1999 W208 CLK230
Serndipity - thank you for sharing the info - will contact the local dealer here for the right parts. Have a nice weekend!
Old Oct 13, 2013 | 08:25 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Expect sticker stock.
A decorative molding, #9 in drawing, warped and became unglued.
Dealer quoted $340 for a new molding. They said it expensive because it was made from real wood.
I just glued the old one back on.
Old Oct 13, 2013 | 08:49 AM
wtc911's Avatar
1999 W208 CLK230
Broken Pull Handle 1999 W208 CLK230 Kompressor
Have check with local dealer - I think my door panel is an older version - it comes in one whole piece...the part pic that Serndipity shared is for a later version that c/w eletric seat...my car is mechanical seat and as per attached part pic (does anybody has part number for the whole door panel (Item 2) please...and mine is anthracite color...tahnk you again.
Old Aug 28, 2024 | 01:30 AM
davidocq's Avatar
A208
[QUOTE=wtc911;5804491]Ciao amici, entrambe le maniglie delle portiere della mia W208 CLK230 del 1999 (destra e sinistra) sono rotte (vedi la parte della maniglia della portiera cerchiata in rosso). Devo sostituire l'intero pannello della portiera o ci sono parti singole che posso acquistare, ad esempio la staffa e la copertura della maniglia? L'esempio di foto è esattamente come la mia, senza la maniglia... Grazie per il consiglio.[/QUOTE
]Qual è quella giusta? Questo ? A2088100554 https://www.google.com/search?q=A2088100554&sca_esv=3d253444b6be7bd5&hl=i t&udm=2&biw=1097&bih=525&ei=oLLOZpS1C72I9u8PouLc4A M&ved=0ahUKEwiUhfOo95aIAxU9hP0HHSIxFzw Q4dUDCBE&oq=A2088100554&gs_lp=Egxnd3Mtd2l6LXNlcnAi C0EyMDg4MTAwNTU0SPgrUIoQWIoQcAJ4AJABAJgBOKABOKoBAT G4AQzIAQD4AQH4AQKYAgCgAgCoAgCYAwOSBwCgBy0&sclient= gws-wiz-serp
Oppure questo?
The upper attachment is different, 2 holes and 1 hole only.
Old Sep 1, 2024 | 11:43 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
bought mine from ebay. Mine snapped in half! Just the arm
