left car running/out of gas-now cranks but will not start
1) replaced battery,2)checked all fuses & relays,3)replaced CPS-Still just cranks but will not fire.
I had it towed & the dealership replaced the fuel pump & the fuel filter-still will not start. they wanted to drop the tank & clean it (9.5 hrs @ $98 per hr.) technician showed me white gunk in the bottom of the tank.
I'am going to the dealership Monday for more information & Ill post then. Any thoughts and/or help is much appreciated
I had a similar situation... when the tanks runs low, it sucks all the crap from the bottom of the tank, straight into the filter. The filter also contains the fuel pressure regulator, and once blocked, reduces the fuel pressure to the injectors. The result is that it will start, then stops after a few seconds. The valve is a air bleed point and used to measure fuel rail pressure.
