So both my upper high beam bulbs are out (02 CLK 430)
Old Dec 13, 2013 | 04:53 PM
eatbeef40's Avatar
2002 CLK430
I think it may be a wiring/fuse problem. I just bought a new bulb and installed it and it didnt even turn on. I went to O'reillys and the guy tested the outlets with the circuit charger thing and it was going from like -0.01-0.04. He told me it may be a fuse problem or wiring issue.. I was wondering how do I access the fuse from the dashboard? or how do I fix this in general.
Old Dec 13, 2013 | 06:02 PM
CJackson13's Avatar
W208 CLK55
Off the top of my head, I believe the fuses for the headlights are located on the side (parallel to the body) of the driver's side dashboard. You have to open your door to access it. Use a flathead or your nail to pry it open. There should be a diagram inside that informs you which fuse does what...
