Will 40 mm offset fit a 2000 CLK 320?
Old 11-20-2003 | 03:50 PM
kkhnouri's Avatar
thanks
Old 11-20-2003 | 04:00 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
depends on how wide your wheels are...
but, if it really doesn't fit, just get 5mm spacers and you'll be fine
Old 11-21-2003 | 06:07 PM
kkhnouri's Avatar
Is there anything negative about putting spacers on? Where can I buy them?
Old 11-21-2003 | 09:34 PM
mmgrad's Avatar
there really is nothing wrong with using spacers... it requires longer bolts, and thats about it...
the only thing people don't quite recommend spacers is because there is a piece of metal that is 'loose' between the wheel & hub... at least thats what i was told..
but as long as the spacer is made by a reputable company, then you should be fine....
Old 11-23-2003 | 11:21 AM
J Lucas's Avatar
So could you use a 15mm spacer on a 20mm wheel to fit a clk.
the wheel is 18.8.5 112x5.
Old 11-23-2003 | 07:41 PM
mmgrad's Avatar
no... that is the opposite of what you need... if the wheel is 20mm, adding in a 15mm spacer would make the wheel = a +5mm offset...
What you would need is to find a wheel that is like +44 offset... and then if you add a 10mm spacer, your final offset would be +34
Old 03-04-2008 | 07:25 PM
newguy2008's Avatar
CLK 55 ///AMG Cabrio, ML63 ///AMG
Would a 35 mm offset front and a 40mm offset rear work on a 2002 CLK 430 - 19 Axis Milanos?
Quick Reply: Will 40 mm offset fit a 2000 CLK 320?
