Convertible roof leaks?
Subscribe
Mar 17, 2014 | 02:36 PM
Just started in the last month. In hard rains both sides of roof leak. Water comes in just above the front and rear window onto the outside 1/3 of seat cushions. Problem may have started some time after I had to manual operate roof to reset it. Roof runs fine, windows reset all the way up. Hard to believe that both sides started leaking at the same time. Have done forum search but no help found.
Reply 0
Mar 19, 2014 | 12:40 AM
Hey Mick,
A couple of checks are cable tension as Benz intended to keep the canvas extra tight.
worn rear window moldings where the door glass meets. (pricey @ 70.00 each).
Last thought would be in the pillar drain molding near the visor area being clogged.
There is a small hole in this rubber for water control, If it gets clogged water will build up in the tops vapor barrier and hold heavy deposits of rain.
To correct find a suitable piece of wire and swabby the debris out.
Cheers, Gator
Reply 0
Subscribe
Currently Active Users (1)
