License plate bulbs
Old Mar 27, 2014 | 05:26 PM
Josh.Althouse1's Avatar
clk430
License plate bulbs
Hey guys I just had a question about replacing the license plate lights. What's the easiest way to do it? The last time I did it my friend and I removed the inner trunk liner and I feel like there should be an easier way. I believe I saw a thread before where someone said there was an easier way to do it.
Old Mar 28, 2014 | 12:40 AM
CJackson13's Avatar
W208 CLK55
I dont think so. I just partially pulled the center of the trunk liner down and clamped the bulb with pliers. It was very easy.
Old Mar 28, 2014 | 09:40 AM
beefstallionAMG's Avatar
W208 CLK55 AMG, W203 C32 AMG, W163 M Class Sport
Wear gloves to avoid getting oils on the bulbs. Open the trunk. On the inside of the trunk there are 4 plastic push clips that hold the liner to the trunk lid. A putty knife or flat head screw driver will work well to remove the 4 clips. Pull back the liner to expose the two bulbs. Insert bulbs and reverse the order. If you update to LED bulbs etc make sure you insert them using the correct polarity.
Note- you can not access the bulbs from the outside like you can on other cars.
Old Mar 28, 2014 | 02:45 PM
etownbala's Avatar
02' CLK 430
+1. Removing the trunk lining does not take long and gives you plenty more room to work.
KRis
Old Mar 30, 2014 | 02:49 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
Correct
