18x8.5 all around?
Old Apr 15, 2014 | 08:00 PM
etownbala's Avatar
02' CLK 430
18x8.5 all around?
Pros and cons of this setup. I just bought rims but found a set that I like so much but they are 18x8.5 all around. While I must say it would be nice to have the same sized tires all around for rotation purposes I question how it would handle with 8.5 up front...anyone have any experience with this? Tia.
KRis
Old Apr 15, 2014 | 09:14 PM
triplefiresoul's Avatar
CLK430
It won't handle as well as 17", I have 19" on mine, and I wish I had my 17". 18" would be in the middle.
Old Apr 15, 2014 | 09:41 PM
etownbala's Avatar
02' CLK 430
I figured I guess my question is whether a 18x8 front 18x8.5 or 18×9 setup function better then 8.5 all around.
Old Apr 16, 2014 | 02:49 PM
Josh K's Avatar
Tesla Model S
I have 19x8.5 all around. Handling should be fine. You'll lose a bit of responsiveness vs. 17's because of the weight but that width up front is not uncommon on 208s
Old Apr 17, 2014 | 01:54 PM
etownbala's Avatar
02' CLK 430
Would you guys go with 18x235x40 all around on 8.5 non-staggered setup?
KRis
Old Apr 17, 2014 | 08:23 PM
CJackson13's Avatar
W208 CLK55
If you want the same tire size all the way around 235 would probably be ideal. Personally I would go 245/35 which is the perfect width for an 8.5 wheel. You'd probably rub a little bit at full lock with the front tires which is why I would suggest 35 sidewall/aspect ratio.
I currently have 245/35/19 up front and sometimes rub at full lock depending on speed.
