HVAC Vacuum Actuator replacement
Old May 3, 2014 | 07:42 PM
coonpuff's Avatar
1998 clk
Need help replacing squealing 2028001575.
Left tempering flap actuator making piercing noise. Located and isolated vacuum at 90 degree fitting. My question is how to disconnect and replace upper control arm buried in dash? I was thinking purchase new part and disassemble old actuator, replace diaphragm, reassemble. My concern is not being able to match new part config to older damaged part.
Any input welcome.
Old May 4, 2014 | 01:24 PM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
The sound and location that you describe is almost identical to one that has been bugging me for a couple of months now. I had the sense that a flap in the HVAC system was partially stuck and a high range piercing sound resulted as air rushed past it. I will be closely following this. It would be great if you post pics of the part or the procedure for pulling the dash and getting to it. BTWhow did you diagnose that thia flap actuator was the cause?
Old May 5, 2014 | 01:21 PM
coonpuff's Avatar
1998 clk
Hello,
The diagnostic was simple.
1.Remove the glove box.
2.Remove air ducting to passengers side vent by wiggling the duct tube left to right out glove box opening.
3.Located Y11 vacuum distributor, in newly revealed opening, strapped to blower housing
4.Pinched and released mounting bracket at top fork and bent out of way.
5.Removed black rubber cover to expose Y11 hoses at the connection nipples
6.Powered ventilation system on, selecting the vent with the whistle and
7.GENTLY pinched, partially - the hoses one by one until noise reduced or disappeared.
Old May 5, 2014 | 05:36 PM
City Rat's Avatar
Veteran: Army
Great write up. My problem is that my high pitched whine comes from the driver's side, left most vent area, the other end of the dash from the glove box.
Old May 5, 2014 | 07:11 PM
coonpuff's Avatar
1998 clk
My/the squeal, whistle is a vacuum leak at the diaphragm of the actuator.
There are multiple actuators and all originate at y11. once y11 is identified - troubleshooting can begin.
See this post for diagram
[URL="http://www.benzworld.org/forums/w140-s-class/1466847-switchover-valve-block-y11.html"]
My leak is in an actuator above drivers right foot.
pics to follow
Old May 5, 2014 | 08:23 PM
coonpuff's Avatar
1998 clk
City Rat - I have the answers
Finally got the courage to tackle my new Possible.
I figured out how to remove the actuator at an angle without damaging the upper control arm.
I'm trying to load pictures and share the progression but cannot get URL pic upload to work.
any suggestions ?
Old May 5, 2014 | 09:04 PM
coonpuff's Avatar
1998 clk
Pinholes in diaphragm causing noise.
Parts just ordered from AutoHauzAZ
2028001575
A/C Vacuum Actuator; For Left Tempering Flap
$33.10
The original part actuator arm can be recycled by disassembling the coupling clip.
Old Jun 11, 2024 | 01:22 PM
fischpj's Avatar
1981 380SL, 2003 clk430, 2009 s550
any suggestions ?
Hi, I have a red-ish orange vacuum line with a black stripe leading to the left tempering flap actuator that has a vacuum leak. I gently pinched the vacuum line in position #3 of Y11 and the leak stopped squealing and traced the line as best I could to the actuator behind and slightly to the right of the ignition key. From what I read in your posts, it sounds like you had the same issue. How the heck did you get that actuator out? I pulled my cluster and can see the actuator, that's about it. It looks like I need to press on the thin black tab and it might come free, but it needs to move up but the underside of the dash is there.
My plan B is to disconnect the line and live with no tempering...
Any guidance would be appreciated.
