ABS ESP BAS error
Tried:
1. Replace Brake Light Switch
2. reset error by turning steering wheel left and right
3. Check fuse #2 on dashboard driver side. Other fuses also seems fine.
Next week I am going to try:
1. Re-seat Brake Switch light to make sure it is working properly
2. Measure battery. My battery is a bit old but I doubt issue lies here
3. Check steering sensor. Also doubt this is source of problem.
4. Wheel speed sensor. This is most likely since errors appear when i go over 20kmh.
Any other idea of what I should be checking? I will be hooking the car to Star machine also. Really hope this is not going to be an expensive fix ....
Tried:
Will try cleaning up wheel sensor and steering angle sensor on my next visit to the garage.
