What could be causing this tapping????
thanks to the tips I've found on this site, I've been able to do a few diy repairs and saved more than a few bucks. Thanks to all...
I've searched the forum but can't find a fix for this one problem... I have an '03 Clk 430 for about 6 mo's now, after it sits overnight or even after 6/7 hours I can feel a tapping under my left foot and then it goes away after a 1/2 mile or so and then it drives fine.
I've had the car 3 years, had the oil pan gasket changed 2 years ago, the tranny does slip occasionally, I put all new tires about 6 mo's ago...ummm??? could that have something to do with it?
Edit.. just checked it and it's very low. Will be getting an oil change ASAP. Why do you think k that is the cause?
As Magma red said oil breaks down over time. It looses its viscosity and thins. I wouldn't be surprised if when you change your oil it pours out like water.
Its much cheaper to follow scheduled maintenance than get behind and have to fix what breaks.
