Sensor plug wire help to internal light, does anyone know?
Old Aug 25, 2014 | 03:56 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Hi Guys
I was trying to find a 12v source at my dome light to plug a dash camera into, rather then feed the wire down the side to the dash. Anyway I have done this now and the dash camera is working great.
The problem I have is that when looking at the wires at the dome light, I opened the back of the small square black plug (about 1" in size) that plugs into the temperature sensor, the wires popped out and I am not sure which way the go back !? I now have no heater fan or climate control as I think this sensor is linked to the system.
Looking at the photo orientation, I thought the wire layout was:
Top Left (Near Pin) = Thick cable yellow and black stripe.
Top Right (Near Pin) = Thick brown cable
Bbottom left = Small grey cable
Bottom right = Small brown stripe
Does anyone have a schematic or could possible open their plug cover to tell me if the above is correct?
Also what fues should I check?
Thanks in advance
Attached Thumbnails Sensor plug wire help to internal light, does anyone know?-sensor-plug.jpg
Old Aug 25, 2014 | 08:13 AM
A1EK's Avatar
Found it was just a popped fuse, problem solved. Thanks
