HELP!! 2000 CLK 320 Ghost in the Machine...
Old Oct 8, 2014 | 02:26 PM
kspilot's Avatar
2000 CLK 320
Hey folks after hours and hours of online reading, and following some suggestions I'm still stuck with a car thats holding down my driveway. Heres a list with attempts to fix.
Main Issue no starting. Started as a temporary problem (Runs, then gas station won't restart etc)
Good battery, power goes to ignition, replaced CPS (thinking second went bad)
ABS, Electric stability control, Brake lights INOP
-Replaced Brake Control unit under dash, still get these warnings
Stereo, sometimes yes and sometimes no
Finally anyone of a schematic for the Convertible opener? Mine popped open and fell apart it appears to be wound up like a swiss watch.
Well thats it any help/suggestions are greatly appreciated its my one car other than my motorcycle and winter is coming soon...
Old Oct 8, 2014 | 02:42 PM
radaddict's Avatar
2002 CLK430 & 2007 E350
Check main chassis ground wire/connection. Have a look at this post: https://mbworld.org/forums/clk-class...what-wire.html
Old Oct 8, 2014 | 04:46 PM
Serndipity's Avatar
2001 CLK320 Cabrio
What the heck is a "convertible opener" ?
Are you referring to the locking/unlocking handle for the front roof bow or S84, the main power roof open/close switch, located on the center console (see attached) ?
Attached Thumbnails HELP!! 2000 CLK 320 Ghost in the Machine...-handle.jpg   HELP!! 2000 CLK 320 Ghost in the Machine...-switch.jpg
Old Oct 8, 2014 | 06:47 PM
kspilot's Avatar
2000 CLK 320
Yup the handle thanks for this! Also I'm starting to think the starter is bad testing tomorrow will show
Old Oct 9, 2014 | 07:47 AM
Serndipity's Avatar
2001 CLK320 Cabrio
I recall reading a couple of threads regarding DIY repair of the handle in this forum or at http://www.benzworld.org
Best way to find them is using the appropriate and order of key words (e.g. 1st word has more weight the the next and so on) when searching.
