2000 CLK 320 BAS ESP LIGHT ON
Old Jan 4, 2015 | 01:41 PM
fone's Avatar
2000 cl320
my clk 320 BAS ESP light is on and won't accelerate if i put it in dive will go about 10 mile max. I tried to turn it off and restart light still and the problem as well.
Old Jan 5, 2015 | 11:09 AM
cindyclk's Avatar
https://mbworld.org/forums/clk-class...iy-repair.html
probably the brake light switch
Old Jan 10, 2015 | 10:13 PM
fone's Avatar
2000 cl320
2000 CLK 320 "BAS ESP" LIGHT ON
I did some diagnostics on it brake switch is working fine. turned the steering wheel left and right light went away but come on again after 5 mins or less. the car won't accelerate stays at 1000 RPM with full throttle. however, if put in gear will move but at a very slow rate. when i turn the key right before cranking will make some kinda of grinding noise coming from the back of the engine don't know what that is.
Thanks for all the replies.
