Verticle rubber internal window seal help.
Old Feb 10, 2015 | 07:35 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Hi Guys
Does anyone know the correct part number or discription for the internal rubber seal the window move up and down in, its in a veritcal U-shaped guide inside the door lining nearest the hinge and goes all the way up to the little tweeter speaker as mine has worn out.
PS for the Right side (UK Drivers side).
Old Feb 10, 2015 | 10:13 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Is seal you're looking for in the enclosed?
Attached Thumbnails Verticle rubber internal window seal help.-g1.jpg   Verticle rubber internal window seal help.-g2.jpg
Old Feb 11, 2015 | 03:17 AM
A1EK's Avatar
Unfortunately not, it is near the hinge side and is vertical about 1.5feet long.
Old Feb 11, 2015 | 08:17 AM
Serndipity's Avatar
2001 CLK320 Cabrio
I just tried to attach a .pdf of the entire W208 Parts List, but it's apparently to large (e.g. 8 MB).
However, I should be able to to email it to you if you PM your email.
